Any plans to allow for transparent projection maps in a vray light:
if you look at the picture attached - the projection map with the black corners is the light, and that one with the the proper transparency is a plane object with a vraylightmtl applied. Using an EXR as a projection map leads to unpredictable results.
Raj
Raj
