So we now have VRay for Max, Maya, Cinema4D, Sketchup and Rhino, and others that I've probably missed. What IS missing however, is compatibility between them. Within this office for example, I couldn't have people working in Sketchup with VRay, and pull in the skp file and VRay materials in tact.
Are there plans at all to have an intermediate markup (ie. xml) that saves material definitions, render settings, etc.? We have vrscene, but it would be nice to pull that apart, so that a vrscene can optionally reference individual materials, meshes, etc. I understand the main obstacle here is inconsistent support of native features. For example, we have Bercon's great plugins, but they're only in Max. There are also vray shaders that won't always be in another program, like DistanceTex is only in 2.0, and Water is only in Maya, but surely these could simply be ignored in a host application that doesn't support it.
What does everyone else think? Have you worked in a pipeline with people working in another application, but with VRay, and have been a little miffed about not being able to bring in their stuff with the materials in tact?
Here's some made-up stuff that isn't xml, because xml is awful:
Code:
import maxDefaults "MaxDefaults.vrsl" shader.defaults = maxDefaults shader.Root = VRayBlendMtl "RedPlastic" ( Base = VrayMtl "JustRed" ( Diffuse = Color[255, 0, 0] Reflection = Map 2 ) ) # Map id name Map 1 "RedTexture" Bitmap ( FileName = "C:\Red.jpg" ) Map 2 "Map2" ColorCorrect ( Source = Map 1 Gamma = 0.8 )
