is there a way to setup each node to read a network Plugins folder ?
  • is there a way to setup each node to read a network Plugins folder ?
    hello,
    I have a question which is kind of Vray related...
    is there a way to setup via a config file the "plugins" folder the 3dsmax slave is reading ?
    because all the times we change a Vray version for example, we have to do it on all our nodes... And we have a bunch...
    some ideas ?
    Regards,
    Tanguy
    plugins.ini in your max root should do that just fine. Just keep in mind that you need to source eventual vray-based plugins AFTER the main vray plugin paths (wich are set to the end on reinstall sadly)
    Regards,
    Thorsten
      Thanks Thorsten.
      I did that but it s a bit weird what happened, I will try again.
      merry Xmas
