Incorrect amount of buckets with DR
  • Incorrect amount of buckets with DR
    Hi all,
    i ve got a little problem here with DR and amount of buckets rendering.
    3 same machines
    intel i7 960 with 12Ghz RAM
    thwo rendernodes show both 8 buckets, but the workstation where i run the DR from only shows 4. WHY?
    i ve checked, i have all cores checked in the performance rollout....
    any ideas? Vlado?
    thanks for help
    Martin
    Martin
    http://www.pixelbox.cz
    are all of the threads on your workstation rendering? or only half?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      If you type in the MaxScript listener,
      Code:
      renderers.current.system_numThreads
      what do you get as result?
        only half
        i will type in the line in maxscript listener as soon as the render finishes and let you guys know
        priority settings on the workstation machine are set to NORMAL
        and MAXEs afinity is with all the cores checked
        may this be because of some settign in BIOS???
        its weird co when i use that workstation as a server when rendering through backburner, it uses all 8 cores......it just doesnt when used as the workstation to run the DR from
        Thanks
        Martin
        Martin
          It may be that you have an old scene, where the number of threads was explicitly specified through MaxScript (that's why I asked). Setting this value to 0 will cause V-Ray to use all cores again.
            the scene is brand new but prepared on a machine with 4 cores....may that be the cause???
            will try that line u suggested anyway when it finishes.
            Thanks a lot....will keep you posted
            Martin
              Hi Vlado,
              it shows only 4 cores when i put the line in the listener.
              How do i set the value to 0?
              Thanks
              Martin
                Just write
                Code:
                renderers.current.system_numThreads=0
                and press Enter.
                  great Vlado
                  THANK YOU!
                  Martin
                    Vlado, this point makes me wonder if its worth exposing num threads in the actual settings dialog as part of the setup. Like most renders, such option would be handy to address problems.
                    Dmitry Vinnik
                    ShowReel:
                      i second that request please
                      Martin
                        or just make it default, and when you open a scene it checks this value and asks to set it to 0 or not
                        Kind Regards,
                        Morne
                          weird thing is that i have never ever set in this old scene anything through maxscript to use only 50% of the buckets!
                          i hardly use maxscript listener....
                          so this thing just happened ......the old scene was done in max 9...now i used 2011 to rework it.....
                          whats also strange is that through Backburner or DR...it always uses all the buckets!....but when u render locally, it uses 50%
                          Martin
                            It's not that strange... V-Ray specifically ignores this option on the render slaves and for backburner
                            • #15
                              OK Vlado thanks for explanation
                              Martin
