Vray versions
  • Vray versions
    Just sent my Plugin to the alpha testers - bug central is here.
    Is there a reliable way of working out what version of Vray is in use?
    Also is there any place I can get info on the latest version of 1.5 (whatever that is) and the differences between that and 2.002 and 2.001
    I have some people who have 1.5 interested in my plugin script and I wanted to try and include some error checking for this build.
    For instance setting a directional value on a vray light will throw and error because the vray directional light is only in 2.0+
    Raj
    Raj
    You will have to parse the output from
    Code:
    classof renderers.current
      but is there a list of vray feature differences between 1.5 (the most recent version) and 2.0 (again the most recent version) so that I can test for errors? As I no longer have access to 1.5 because I upgraded to 2.0 a list would help in removing most of the incompatibility errors.
      Raj
        There is the changelog; I believe the 1.5 builds are still available from our site, so you can install them and test.
          can vray 1.5 and 2.0 run on the same machine?
          will I run into licensing problems running both as I only have a single licence.
          Raj
