Creating reflectors on cars, bikes -- and also reflective tape
  • Creating reflectors on cars, bikes -- and also reflective tape
    I have a night time scene and I really want to create the effect of a headlight bouncing off a reflector -- actually reflective tape (like you often see on the back of trucks).
    Has anyone had any success in doing this? It seems to be a hard effect to recreate -- I want that bright "lively" appearance that reflectors exhibit in real life.
    I have had good results with making fairly realistic geometry for reflector lenses, and using this normal map (tiled appropriately). Use a material with high relection (white) and very high fresnel or just turn fresnel off.
    For the reflective tape effect you could probably do something cool with the VrayCarpaint shader - it does a nice job of metallic effects.
    /b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
      That's clever. Is there anything you haven't figured out, Brett?
      David M. Foster
        Very many things, but top of the list is how to retire young (ish)
        That map is not my invention btw: I scavenged it out of a material somewhere along the way.
        /b
        Brett Simms
          Thank you Brett, for the technique and the map. Seems to be helping.
            And once you figure out that retirement thing, hope you'll share that too...
            David M. Foster
              that secret I will never share, but I'll also never get it - so no harm done either way
              something that I forgot: you may find that tiling that little map too many times creates oddness with Vray and VrayRT. If you need to tile it extensively you may want to try creating a tiled version in Photoshop, say 20X20 or whatever, and use that in Vray. It seems to help with some of the anti-aliasing problems that can crop up with too much tiling.
              /b
              Brett Simms
