using free linear light
  • using free linear light
    i am using some free linear lights with an IES file for distribution and shadows set to shadow maps. my problem is that once i have dropped just a single one of these lights into my scene - the rendering time has gone through the roof.
    here's the image without any of the linear lights:
    has anyone else used the linear lights with vray? had the same problem?
    here is the image with the linear lights:
    at 600x600 it took 4 hours to render - bucket mode with 'medium' presets for the irrad. map.
      yeah ..... i get the same problem.....
      but some ies files go fast and some go slow ....all to do with the light distribution i geuss..... dont know .......always miffed me...its a real shame cos you get some real nice light falloff with ies.
      Natty
      Natty
      http://www.rendertime.co.uk
        Proces2,
        Try this...make a renderable rectangular spline a above and bit smaller then your ceiling...maker sure to give it some thickness. Put a VRAYHDRI Map http://www.d3cg.com/vray/white3.hdr to the self illumination slot of a standard mat. Adjust the hdri mult to get the desired lighting effect. It's a quick work around...here is a quick example...
        regards,
        Corey
        Corey Rubadue
        Director
        Chaos Group
          awesome. thanks! i'll definitely give that shot.
          i always try to use the IES file first, just so that i know that the light distribution is relatively accurate. but, it looks like you got just about the exact same distribution as i got.
          sean
            sure thing...
            The mult. value cannot be too high or you'll get some artifacts as you see on the column in my image.
            corey
            Corey Rubadue
            Director
            Chaos Group
              Corey,
              I just tried youir suggestion but I can't seem to get it to work? Are there any other settings that need to be applied to the base material?
              I have self illumination set to 100 with the hdri in the slot and the multiplier set to 30 with no luck.
                http://mywebpages.comcast.net/crubadue/vray/hdrimat.jpg
                http://mywebpages.comcast.net/crubad...y/hdrimat2.jpg
                Try these settings. I can upload the max 5 scene if useful.
                corey
                Corey Rubadue
                Director
                Chaos Group
                  Corey, got it to work, thanks again for the help!
                  Tony
