Urgent ---error code 126 failed to initialize plugins
  • Urgent ---error code 126 failed to initialize plugins
    Sorry but this is urgent and I need a fix now.
    Came in this morning, started the computer Dell xp 64bit Vray2. max 2011.
    Loaded the vray licence server as normal.
    started max and all the plugins won't load
    error loading DLL <C:\ programme files\autidesk\3D max 2011\plugins\vrayplugins\hairvrobj2011.dlo. fialed to initalize
    error code 126
    I am screwed if I can not get this fixed now, i have a deadline today.
    Help would be parreciated.
    Thank you
    phil
    is it only the vrayplugins that fail ? Make sure that the order of plugin paths is correct in plugin.ini (/vrayplugins beeing after /plugins)
    Regards,
    Thorsten
      Hi
      I had a look seems fine.
      Why would it change from last night to today.
      Strange
        There are several plugin.ini files; one is in the root folder of 3ds Max; another is in the local user folder - make sure that both are ok.
          what am I looking for exactly.
          This is the plugin.ini
          V-Ray additional plug-ins=C:\Program Files\Autodesk\3ds Max 2011\plugins\vrayplugins
          from the root folder.
          Why would it have changed from the time i turn off my computer last night to this morning when I turned it on?
            Anybody help me as this is not being solved.
            Thank you
            phil
              Found this on Evermotion site .
              thank god and it worked.
              The solution is to re order the plugin files in 3dsmax plugins folder. Switching the files that live in the vrayplugins folder with the two vray files that live out side the vrayplugins folder.
                Which means that the order in the plugin ini is wrong hence the exchanging of the files fixes it. The better solution would have been to fix the plugin.ini for various reasons.
                One thing that can break the plugin.ini is installation of any plugin (or vray)
                Regards,
                Thorsten
