photons slower than irr map??
  • photons slower than irr map??
    just did some tests to get into photon mapping.
    what i did was to set up a really simple interior scene. all objects have vray materials. the scene has a direct light ( sun ) and env. light blueish multiplier 1.0.
    with irr map setting high the rendering takes 44 seconds.
    then i switched the second bounces to photon maps with standart values.
    the rendering takes much longer..
    i played around with the settings, but the photon mapping always took longer..
    what is wrong??
    http://www.pixum.de/viewalbum/?id=892835
    regards
    s.wolf
    tried it with the cornell scene.
    saves me 6 seconds..
    regards
    s.wolf
      well. the photon tutorial scene should have been atleast half the render time of your irradiance mapped version so it seems a step was missed there
        ok elf!
        you are right with the cornell scene..
        but with medium seettings and second bounce depth of 3 photons save me 15 seconds..
        but what os going on in my test scene?
        regards
        s.wolf
          come on! people!
          is nobody trying photon mapping?
          or am i the only one with these strange results?
          regards
          s.wolf
            photons are much faster than normal irradiance map. i don´t know if a small scene like the cornell box would show that. in a bigger scenee where you have to put a lot of lightning in to get it bright, photons are great. but you have to handle them with care. sometimes they create white spots, then you have to tweak the settings. normal irradiance calculation is easy to handle but with photons you can save a lot of time in large scenes with "large" rooms which are heavy to "light up".
            o hdear...my english is terrible today.....it´s the heat outside
              @metroberlin: did you check my samples?
              regards
              s.wolf
                Hi Stephan can you send me your scene?
                Gonçalo
                  the photon master
                    Lol
                    here is a comparation
                    Irradiance map
                    Photon map
                    Gonçalo
                      Wow, very nice. Can you please share those 2 scenes (irr. map/ with photons). Please....
                        Hi Luka,
                        I ve sent the scene to Stephan, if he dont mind he probably can post the examples here.
                        Gonçalo
                          and if goncalo does´nt mind i can forward his scene .
                          regards
                          s.wolf
                            if goncalop approves as well i would be most interested in seeing the scenes.
                            5 years and counting.
                            • #15
                              me also
