render element plugin, Intersection / shade / postillum
  • render element plugin, Intersection / shade / postillum
    Hi there,
    Being a newbie to the vray sdk, these might be quite obvious questions.. It was fairly easy to write a simple render element based on the supplied samples, but now i seem to have hit a roadblock.
    The render element i have should not be using transparency compositing of the fragments, as i want the closest fragment's value to be displayed only (so it should ignore reflections / refractions etc. its a matte pass). The example i based my work on was inheriting VRayIntersectionShader and did its shading in the shade() function. However, i dont seem to be able to do anything in there that would make the end result ignore transparency.
    I tried using other examples, where the shading is done in the PostIllum function, but for some reason PostIllum never gets called by vray. I rebuilt some of the examples (like VRayReflectionElement), and even those dont have their PostIllum called. Strange.
    What am i missing?
    cheers,
    laszlo
    Nevermind, i've figured it out. I had to overload the addValue function and make sure fbm_ray type blends are only added if flags==0. I had to play with it a fair bit, because by accident i also had faulty code in the shade function.
    oh well.
      Heh ok, I see you figured it out
        Hehe yeah
        But then, i tried to get fancy. I've actually added 3 additional channels to the image from my render element, managing each with its own instance of a RegionChannelCallback object. It all works great in the vray frame buffer, i see all 4 channels added (first is color, rest 3 are integers) with all the proper values. But it appears that the additional channels arent saved into the EXR file.. I probably shouldn't be doing what i'm doing, right?
        cheers,
        l
          I did some additional troubleshooting here. It might be a nuke issue. In fusion i see the additional channels (even though they arent integer, but float). In nuke it seems like the 3 channels are merged into one "other" color layer, arbitrarily chosing which is r,g and b.
          Further investigation in progress...
            nevermind.. im an idiot. Ill just rename this thread 'nevermind'.
            The channels are all there, showing up just fine. They are converted to float, but that probably happens in the comp applications.
