Network render: Incremental add
  • Network render: Incremental add
    If I render a network job and need to cancel it and my VRMAP is partially completed, can I add to it later?
    Vlado?
    Dont think so but want to make sure.
    thanks
    "It's the rebels sir....They're here..."
    well. i dont know about network rendering, but incremental add to current map is designed to add to your current saved map
      If its completed and saved then you can always add more to it.. Not sure if its saved after each frame or not though nowadays..
      Pretty much if you have a vrmap.. you can add to it! one of the problems back a few builds was that you couldn't load the vrmap in a network render to add to it.. so you end up using an interactive copy of max to do that.. No idea if there is a way around that yet with the maxscript addition they added a bit back..
      *shrug*
      Dave Buchhofer. // Vsaiwrk
        Chatted with Vlado, load scene on machine, from file render 1 frame then do incremental add locally.
        Not too sexy, would really like to see this capability over the network.
        Thanks guys!
