I was wondering if there is a way to set up a 3dsmax viewport to be panoramic, I am using an spherical camera in vray to create my own hdri maps, but the problem is the viewport only shows a clip of the whole panorama, if I could see the entire thing would be more useful...
Panoramic Viewport
Use VrayRT, easiest way to work with spherical cam....Maxscript made easy....
davewortley.wordpress.com
Follow me here:
facebook.com/MaxMadeEasy
If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
Yep, if you switch one of your viewports to Activeshade then you can use Vray RT with a standard camera and then use the Vray Camera Settings in the Render Scene Dialog, overide the field of view and get the full 360 deg view. I've used this method before, I mainly use it for just positioning proxy objects as it's almost as quick as a viewport. It's a little bit of a hack, but it does the job.Maxscript made easy....
Follow me here:
