IRMAP problems, URGENT
  • IRMAP problems, URGENT
    Anyone having any problems with IRMAPS saving/reading ok?
    Recently we are having problems with our IRMAPS saving and reading.
    For example we just did a small test of 3 frames, watched the IRMAP which looked fine. Then rendered the frames doing a from file and it is almost like the lights are there but the GI is turned off, like the IRMAP is not being used. Any guesses? The IRMAP has size so there is info in it.
    Checked the paths and names about a thousand times.
    This is a big problem.
    Wondering if this is related to the MAX5 - Win2K SP4 corruption problem.
    Anyone else get this?
    "It's the rebels sir....They're here..."
    Hi Dman,
    I've experienced similar problems before. Usually resaving a completely new map solves my problem. You're definately saving your IRMAP to right location right? Where all your machines can read the file?
    By the way, don't SP4. Discreet have issue a warning that it will corrupt your files.
    SunnyC
      Yeah it all seems well now, .03i will help this, testing now.
      VRay will try to save to the location 3 times, if it cannot it will drop the IRMAP into the autobak folder of the machine rendering it so the IRMAP does not get lost. Funny, now I have a fix the problem has not reappeared.
