blurry reflection calculation depth
  • blurry reflection calculation depth
    until what depth does vray calculate the blurry reflection effect?
    lets say i want a reflection depth of 5, but just the first reflection blurred to increase rendering speed.
    see example:
    andre
    re
    Off topic to what your asking, but did you chamfer and smooth your tight corners..they look nice
    Indecisive archictects will be the death of us all.
      shytiger: the objects are loft-objects with filleted edges
        if you are using heavily blurred reflections there is not a lot of point having a depth of five, one or at most two would be sufficient i would think... after all if your reflections are that blurred, youd be able to make out the object reflected, but would u notice whether the reflected, blurred object had reflections on or not?
          Re: re
          wow smooth corners!
            super gnu: a depth of five is just an example. i used a depth of 3, but i want to turn off the blurring for the 2nd and 3rd reflection.
            www.nulleinsbild.de/files/chain.mov
            andre
