another "line" problem....
  • another "line" problem....
    in my workflow i like to use lines with "renderable" turned on an a relativly small thickness to create "wireframes". no when i try to render with vray these lines look terribly jaggy - even AA set to very high numbers.
    when i use the scanline renderer the lines are perfect.
    since other parts of the image are vray-materials and -lights i have a
    hard time putting the scanline "wire"-image and the normal image together
    with photoshop.
    any idea what i do wrong?
    thanks. nlo.
    btw: one more question (not really vray) is there a nice 3d-polka dots texture out there? i recently needed one but i could not find any (max 5.1).
    render forza!
    Office Le Nomade, Vienna
    web: www.oln.at
    blog: blog.oln.at
    Try SimbiontMAX, a free plugin from darkling simulation,
    they have awesome procedural textures,
    including 3D dots.
    www.darksim.com
      for the jaggies line, try to increase the irradiance map rate
        nlo: what AA settings have you tried and what is the result?
          Yadla: thanks, will check it out.
          restoeboemi: it doesn't matter if i use gi or not...
          vlado: sent you a private message with some pics...(ongoing competition)
          btw: great community here. i hope chaos will keep the forum open to everyone.
          render forza!
          web: www.oln.at
          blog: blog.oln.at
