vray displacement question
  • vray displacement question
    im currently using the demo version.
    my question is, is it possible to map only a few polygons of ONE object with vray displacement?
    let me give you an example.
    when i modell a house i create the lines of the walls and then extrude it.
    now i have 2 walls (2 polygons) i like to map with a brick texture and for more realims i like to add the vray displacement.
    the problem is, that the displacment is added to ALL polys but the brick texture is only added to the two polys (like it should be).
    is it possible to achieve this with vray, and if the answer is yes can you please explain how?
    thanks!!
    re
    detach the polys or group of polys that you don't want to be displaced....or use uvwunrap.
    Indecisive archictects will be the death of us all.
      detach the polys
      stupid me.
      sure thats a quick solution, thanks.
