Multi Displacement
  • Multi Displacement
    Hi All. I try to make a realistic terrain with displacement. First I create a Grayscale bitmap for the mountains in brute and apply over a plane wich have modified for approximate to the final look. The first displacement look good and make erosion and surface in the render.
    The try to make more complex look and apply a second vray displacement with a sand/rock texture. I think that works. Nope. Only apply the displacement on top.
    I try then to make a composite material with the two materials. Doesnt work, because I need more displacement in the mountain and less in the sand/rocks.
    Then, I suposse that Vray cant apply two vray displacement one over other. I anyone have a trick to solve this, please post it.
    Thanks!!!
    Try to use a mixmap...
    -Tom
      ok
      -Tom
      Ok, this works better, but not have the same results that applying two displacements...
      Edit to say that works perfectly with another sets of maps
      Thanks!!!!
