Render bitmaps
  • Render bitmaps
    Seems VRay(GI is disabled because I hear VRay can render much faster than default scanline render) cann't render bitmap better than max default scanline render, especially when I want to render large image such as 4000*3000(Small render size makes less difference in between). The texture details cann't render clear, so correctly at this time(I use Adaptive SuperSampling. Higher values dosen't improve much as have tried). But scanline render did good. I have rendered imgs to clarify the trouble but don't know how to upload it. And one more, under the same lighting condition, Vray render result tends more grayish. Any helps? (I use vray free for viz4.0)
    Thanks.
    -Percy[img][/img]
    supersampling does not work with vray, SS is a scanline feature. You have to use the AA in vray. setting bitmap filtering to none and use adaptive aa at 1/3 should give a good result, lower settings might work fine too.
    /Thomas
    www.suurland.com
    www.cg-source.com
    www.hdri-locations.com
