Dark reflections
  • Dark reflections
    May be this was discussed earlier, but I could not find the right answer.
    Here is my problem. I have a room with one window, also have a direct light for the sun. The environment and background are pure white. the floor in the room is reflective but in the reflections the background is gray. How this can be fixed? I want my white background to be reflected white...
    Thanks
    Sounds like you are using the exponetial color mapping, you should increase the dark color mapping value to at least 4.0.
    Hope this helps
    Gonçalo
      Is that the only way? Cause if I set the mult. to 4.0 (currently it is 1.5)everything becomes washed out, I didn't want to set up the lighting again. May be there is an alternative way?
      Thanks.
        you might want to set your Environment Reflection colour to white and increase the multiplier to something like 10.
        sigpic
        Vu Nguyen
        www.loftanimation.com.au
          "you might want to set your Environment Reflection colour to white and increase the multiplier to something like 10"
          This one helped, thanks a lot.
