What is skylight portal used for on the vraylight? I have noticed people putting vray lights in window openings.....Why?
skylight Portal
But.. Is there any real advantage to doing it this way as opposed to just using a normal VrayLight?Dave Buchhofer. // Vsaiwrk
the sky light will focus the environment (Override max's env.) You have to place them in an opening and hide the glass objects. calc the Irradmap, render final with "Irradiance map" From file. obviosly you can't use environment in animation, unless it's a pre-calced walkthrough.
It seems that when i turn on the skylight portal it will grey out all other fields in the light parameters. So how do you control the multiplier, or the intensity of the light? Or do you set the desired multiplier to the light before turning on skylight portal.
