Multiple Displacement maps
  • Multiple Displacement maps
    Hello, I'm new on the forum. I was wondering if you can place multiple displacement maps on one polygonal object. I have a object where I need one texture map on the arm and another one on the torso. I need the disp strength of the arm texture map to animate(change in magnitude) independently from the torso map. If you can do this, how do you go about doing it? The Vray Displacement modifier only seems to recognize one texture map (the one it accepts in it's modifier slot). When I try to add a second displacement modifier, I get a shredding effect in the rendered image. I wish the vray true displacements were in the vray material instead of in a modifier. I believe this would make for a more intuitive workflow.
    http://www.chaoticdimension.com/foru...pic.php?t=3810
      Thanks asango, I'll look over that post tonight.
