matte material in vray?
  • matte material in vray?
    i tried max matte material in vray: i renders correctly, but alpha is always
    opaque and shadows don`t affect alpha. what can i do?
    thanks
    shaggray
    Use the matte support in VRay instead, either through VRay properties in the quad menu, or with a VRayMtlWrapper.
    Torgeir Holm | www.netronfilm.com
      hi egz,
      i tried what you told me but i dont`get the result i want.
      the attached picture shows max`s lighttracer (top)
      and vray (bottom) plus both alpha channels.....
      please, can you tell me what i am doing wrong?
      thanks,
      shaggray
      http://www.mvd.org/beton/hdri_teapot_rgba.jpg
        Set the matte objects alpha contribution to -1 and turn on shadows and affect alpha
        Like this:
        Same settings would apply to the VRayMtlWrapper as well.
          aaaahhh!
          the "alpha contribution" setting was my stumbling block!
            Why -1 for alpha contribution? I noticed that changing this between -1 and 0 has no effect.
              put something behind the matte object and you will see.
              1 gives you a solid alpha
              0 gives you a transparent alpha, showing the solid alpha of objects that might be behind it
              -1 will mask out objects behind the matte object as well
