map path problem
  • map path problem
    my DR is working fine, I can use all cpu's, but without my bitmaps...
    where do I have to place my maps for DR?
    I have a server where all my maps are stored in different folders, every machine has access over network. but it doesen't work!!!
    what's the problem, I can't find it...
    thanks in advance
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    have a look into 3dmax.ini..
    regards
    s.wolf
      Are you using UNC paths? Probably the easiest way to make sure is to load your maps through "my network places".
      Eric Boer
      Dev
        ...thanks for help. but I'm using UNC paths...!
        I have a solution to test, but it's not my favorite way to do.
        I'm glad to get more and new informations.
        best regards, themaxxer
        Pixelschmiede GmbH
