MAX 6 and vray
  • MAX 6 and vray
    I just ordered MAX 6 and i wonder if my current version of vray would run fine on my machine...
    another issue is that i have both VIZ 4 and soon MAX 6
    would i be able to run both programs with the same license of vray???
    i work with brazil too and i have been able to do this freely.
    Thanks!
    Its on a per machine basis.. I've got both running here also..
    Only oddity is that it appears to follow the login.. So multiple logins on the same machine will need multiple auths.. (Or a copy of the auth.. but thats beyond whats going to end up on here.)
    Dave Buchhofer. // Vsaiwrk
      thanks!
      any news from the next release of Vray that will work with MAX 6?
        There is already a Vray "m" version for Max 6....
        Gonçalo
          thanks for the info...
          I have version k currently.
            VRay already has a recompile for Max 6 which you can get from the registered users download page.
              hi there
              can´t find the max 6 download in the user area !!
                It's only on the registered users are so far (it's been there for several weeks). I guess the demo will be out a little later.
                Torgeir Holm | www.netronfilm.com
                  Hi there,
                  I´m in the registered user area...
                  but all i see is first "Download installation(recommended)"
                  with 2 links for max 4 and 5
                  and another point "Download plugins only(advanced users)"
                  with versions for max 3,4,5 and 6. But in this sections there are no
                  download links
                    do you have the basic version? For the advanced version there are 4 links (max 3, 4, 5 and 6).
                      I have the advanced version.
                      but as described above.. i only have these two links for max
                      4 and 5
                      the links in the plugin only section are just text.. no links..
                      however.. i will contact chaosgroup
                        Vlado tells me only the regular advanced version has a recompile so far. So if you have the EDU version or an NFR version they are not available yet.
