Hello I've been reading up through your threads about DR and trying to learn from your pains and aches with it but evidently that wasn't enough
ok I did the usual:
strated to do DR with my onw comp at first (usuing the comp as a DR slave and cliet)
I set up the spawner (tem director is C:\temp)
and the start up the DR manager which see the machine itself - I right click and enable it as a slave.
my file (max) and bitmaps are all visible from the network - since I'm using the same comp that should really be a problem.
I set it to bucket mode and hit render - two things happen:
1) and error shos up:
"Error: Reentrant call possible exeptions"
2) I see in the DR manager that it locates the scene /preps the scne and the it says "Disconnected" all that in the status area next to the slave server....
any ideas, things I omited/forgot????
thanks a bunch in advance!!!
paul.
ok I did the usual:
paul.
