cove lighting - suggestions on how to???
  • cove lighting - suggestions on how to???
    ok guys I need to do some cove lighting similar to this :
    http://www.residential-landscape-lig...ove%20Lighting
    (sorry for the long link)
    now if I was in Brazil the way I'd do it is by applying an standard mat with an output mat in the diffuse chanel to the "hidden light object" and maybe a blur render effect to the object's G-buffer to make it glow -
    but since I'm in vray, i was wondering if you could enlight me with better/more efficient ways - or simply different - to do this .
    thanks a buch in advance...
    paul.
    the same way is the best I think. Hideing is not neccesary just a proper modeling.
    Self illuminated mat. apply on just a thin line, gi will do he rest, i think it will look better than the original (smoother).
      thanks losbellos!!.....
      the main reason i was asking is because I thought vray had some kinda system/lighting speific for object lights - such as FinalRender (see object Light)....
      or that there was an esier way to set it up - not that that is difficult either.
      anyone else??
      paul.
        you might want to put the output map in the self illumination slot. then change self illumination to color instead of a percentage. then you might want to put that material into a vray material wrapper and use the GI multiplier and the output map to ballance a good image
