Seperating mesh elements
  • Seperating mesh elements
    When exporting by layer, things are grouped. For example aluminum layer. Now, If I decide to change some of the objects within that alum layer -
    Is the only way to change materials based on selection by using subobject materials?
    Is their a way to explode objects from the editable mesh and re-assign to a different material?
    TIA!
    Arkitec
    Collapse to an editable mesh and then use the explode but or ungroup...
    Two heads are better than one ...
    ....but some head is better than none.....
      Im sorry I should have been a little clearer! Is their a way to do this and allow more control of which objects are grouped with each other. It seems the only control is the spinner next to explode....Which I dont have control over which objects get group with what.....
      So, what does the spinner do exactly, is the number related to how many groups are created? Is it a %??????????
      I guess the thing I can do is explode with a high spinner and just GROUP when I am finished? The problem is I have SOO SOO many objects and faces....
      Thanks Mike for your response.
      Arkitec
        The spinner is the angle threshold if you use a large angle of 180 It will only break out the objects that don't share faces, where as 1 would seperate all but coplanar faces.
        Eric Boer
        Dev
