Clearing VRSRVLOG.TXT
  • Clearing VRSRVLOG.TXT
    How can can I delete some info from VRSRVLOG.TXT the file size is approaching 200megs and every time I open it and manually delete the previous render info it wont let me save it. If I try to delete it always says, the source of destination may be in use and wont delete it. It is not a read only file either.
    By the sounds of it you have the vray spawner acting as a server and all you should have to do is go into your services and stop the service, then you should be able to delete the file. In theroy vray will create a new file so you dont have to worry about that. If all else fails reboot in to Safe Mode then delete the log and reboot normaly.
    Hope that helps.
    -dave
    Cheers,
    -dave
    ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
      Thank you much, such a simple process but I would never figured it out with out you. Future releases should have the option to clear these through the DR servers box.
