Channel Rendering
  • Channel Rendering
    Hi all,
    I m actually working on exterior view for a project.
    I was wondering if anybody could help me about channel in Vray...
    I just wanted to get several layers during rendering.
    For exemple, what would be the best way, for an exterior view of a building to get:
    - one layer for the ground
    - one layer for the trees
    - one layer for the building
    - one layer for its glass...
    Thx...
    youre trying to get objects to separate out in a final render? You can always hide the visibility of object and render individually. and if youre talking about rendering out to separate photoshop like layers, Cebas has a plugin called Psd Manager which will separate them.
      You mean Ghost Paint plugin?
        psd manager does not work with vray!
        render elements is on top of the wishlist i guess..
        regards
        s.wolf
          lol- didn't realize that. guess i wont be getting psd manager anytime soon.
            maybe you could check node render id, give to your objects a different g-buffer id, for example 2 for all glasses, 3 for trees. you render your image, then select from the VFB the object layer and then u can use it as a mask, to separate the tree, glass etc. I mean if you want to post work it.
              psd-manager works with Vray! You can create mattes for materials and objects and use them to edit individual parts of the image. Of course you can not add render elements to the PSD file since Vray doensn't support render elements, but all the other stuff works. Try the demo.
              Daniel
              Daniel Schmidt - Developer of psd-manager
                http://www.rpmanager.com
                Try this http://www.rpmanager.com
                Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
