maintain renderslaves (3ds max)
  • #31
    I think an "Idiot" proof help section for this in spot3d would be very advantagous. I dont see why anyone with more than a couple of machines would not see this as a time saver, especially as a lot of the info would be transferable for use with other plugins.
    An amazing solution would be to have the installer have an option for a shared install location.
    I'd see this as a sooner rather than later request. I can see a number of ways people could really mess their machines up if they do it wrong!!
    • #32
      Yes, it's on the "to do" list to write a section on this in the help index. However, as you say, it's easy to mess things up
      • #33
        Beware, updating the path environment variable is fine, as long as you're only working with ONLY ONE 3dsMax version!
        Another thing that is bothering me right now is: where is the information about the license server(s) stored? I would like to simply execute a .reg key or copy a .ini file on startup if i change anything in there instead of going throug all the nodes by hand.
        Thanks a lot,
        Michael
        This signature is only a temporary solution
        • #34
          The vrlclient.xml can be found here C:\Program Files\Common File\ChaosGroup
          Also you can set a path to the vrlclient.xml file with this windows environment: VRAY_AUTH_CLIENT_FILE_PATH
          Zdravko Keremidchiev
          • #35
            Thanks a lot for the information Zdravko!
