No problems with character animation any more
  • No problems with character animation any more
    These settings are the best for ALL cases of any animation of Characters. For 512x288 to 640 x 480
    1.Dont start the animation from 0 frame!!!!!
    Start the animation from 10 frame better
    2. Antialithing - Adaptive -1,2 Multypass -Yes Rand - No
    3. Dont put any filters to Antialithing
    4. Irr map. There should not be more difference between MIN MAX than 1
    I have -2, -1 but -1, -1 is better
    Other three parameters of IRR equal 0,4 0,4 0,4 or better 0,3 0,3 0,4 (0,1)
    HSph - 50
    Interp - 40
    Secondary: Subdivs - 3, Depth - 5
    Interpolation of Irr - Least squares fit
    Sample lookup - Nearest
    samples 15
    Use current...- Yes
    Randomize.... - NO !
    Check........... - NO
    Multyframe Incremental mode
    QCM
    Amount = 1
    Amount(2) = 0,9
    NOISE = 0,008
    If you want better NOISE = 0,007 but the time increase 15%
    Min Samples = 15
    Colour Mapping - Exponential or what you want
    System
    Raycaster Params:
    60 0,0 0,5!!!!!!!
    Render region devision - Region Count
    X = 1 Y = 1 //ONLY SO
    Lighting settings - choose 40 subdivs for each Vray light and 40 for others
    Scene 200 000 poligons take 5 minutes for the FIRST frame and 1,3 - 2
    minutes for the SECOND and Tne next frames
    well, multiframe incremental mode means also,
    that if you move box on a ground you will see a line behind it over time.
    I used such a kind of setting 1 year ago, when doing a add. for a company. I always tried to avoid moving the camera behind the objects that move.
    A nother good thing is to use an Vray Area light that gives some direct light on your moving objects. Even if is week it helps making a good image.
    robert
    I'm registed believe me! Just miss that logo.
      You are right about direct lighting. It alwaes help. But if your character is inside interior these settings halps too to avoid bugs on the walls and the characters. Try to observe ALL these settings(EACH POINT)!!! Only IF you OBSERVE EACH SETTING you will get Best Result/Time
      And I must say more - The settings remove that black line
        Multiframe Incremental mode ?
        are you shure about this one?
        i thought thats for non animated scenes only?
        Reflect, repent and reboot.
        Order shall return.
          Multiframe Incremental will not work for moving objects.
          -Richard
          Richard Rosenman
          Creative Director
          http://www.hatchstudios.com
          http://www.richardrosenman.com
            back to the drawing board alkonst
              did someone test this?
              Order shall return.
                I tested this in 98 scenes. It works good. I can give you an animation of characters with it. Everythings is OK now.
                If you have any questions ask me. I think even Vlado does not know the way to set up character animation solution. But this works
                  this sounds great!
                  are you shure about this setting: Multiframe Incremental ?
                  Order shall return.
                    Yes sure. Try to use the settings, ALL SETTINGS!!! If you have any problems tell me and I will help you
                      ok, i tried it.
                      rendertime is above 3 hours per frame.
                      the bucket looks like its only 1 pixel in size and it takes VERY long to go through the frame.
                      i rechecked every setting twice.
                      there is a man sitting on a seat in a plane in my scene,
                      nothing special.
                      no secondary bounces on.
                      Order shall return.
                        I think he meant to only have one bucket per frame not 5 million I tested this recently(just the render region part) it shaved 40 secs off a ten minute render compared to 128 x 128 render region. It saves on the time used to make each region fit together.
                        Eric Boer
                        Dev
                          RErender: it also makes ram usage skyrocket, so it won't work well on all scenes.
                          Torgeir Holm | www.netronfilm.com
                            Alkonst, try the following test with your settings:
                            Create a plane. Create a sphere. Animate the sphere moving across the plane from left to right. As predicted, the sphere will leave a black GI shadow trail across the plane.
                            I've followed your steps EXACTLY (with the exception of the 1x1 bucket size) so unless I'm missing something, this method will not work.
                            -Richard
                            Richard Rosenman
                            Creative Director
                              That makes sense. good point.
                              Eric Boer
                              Dev
