Ambient Occlusion Pass
  • Ambient Occlusion Pass
    Hello-
    I get these Revit models, that are Frankenstein, and ambient occlusion passes are a nightmare. Is there a way to do an ambient occlusion pass with double sided materials so I don't have to deal with the normal's?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hmm..with vray2sidemtl ?
      You have to render the AO pass via VrayLightMat + Vray dirt and have to turn on 'emit light on backside' in the VrayLightMat
      Best regards
      Björn
      PS: I remember there was a tutorial about this on ronenbekerman.com. Turning off 'emit light on backside' helps to find flipped normals vice versa
      visit my behance profile
        How Exactly you guys do AO pass? VrayDirt as material?
        Luke Szeflinski
        :: www.lukx.com cgi
          To get AO pass - simply add VrayExtraTex in the Render Element and put there VrayDirtMap (subdivs about 20) - it works for me
          www.pixelmustdie.com
            Yeah thats right, i usually use ExtraTex too..... but the initial problem in this thread was how to handle models with lots of flipped normals and not how to setup an AO pass in general. Flipped normals appear to render black in this approach.
              How about using this script?
              http://plugins.angstraum.at/vrayao/index.htm
              :: twitter :: Portfolio :: My 3D Products :: ...and ::
                yes. this is the issue. I'll try the 2 sided material.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Hm, we have a "double-sided" option in the VRayDirt texture, but it doesn't seem to be exposed in the UI. If you need this urgently, please email me to vlado@chaosgroup.com and I can get you a build with this option.
                    Maybe you can hack this in for the next release , would be helpful in some cases
                      thanks, for plugin tip.
                      Luke Szeflinski
                      :: www.lukx.com cgi
                        Did you happen to try using Mental Ray just for the AO pass? I had the same issues with a Frankensteined Revit model and was running out of time. Out of desperation I tried Mental Ray and seemed to play better with the model even though my skills are very low with that render engine.
                        Sean MacNintch
                          I did use a double sided material, and it worked like a charm.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
