Depth of Field (DOF)
  • Depth of Field (DOF)
    I am trying to get a strong DOF on the foreground. What am I doing wrong?
Name:	light house - northeast.jpg
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    i think you have to try lower f-stops. try say 0.2 or something. thing is, on an architectural scale scene youre not going to really get a shallow depth of field with a normal camera setting. either scale the scene down to macro sizes and use natural cam settings, or keep it the same size, and use unnatural cam settings.
    i usually adjust fstop/shutter speed to get dof/ moblur correct, then adjust iso to get exposure correct.
      nice render by the way
      sure you want heavy DOF? itll make it look like a miniature.. maybe thats the idea though
        the DOF indicators do not exactly show the area of "focus" in the intuitively accurate way you might expect unfortunately. I'm guessing it's a scene scale thing. Try an even lower f-stop?
        Brett Simms
        www.heavyartillery.com
        e: brett@heavyartillery.com
          you could do that in photoshop very quickly with a gradient mask and the lens blur filter.
            I guess I want to use this scene to play with DOF, and not actually use the results unless it works. I never thought about lowering the f-stop below a real value, but I guess it makes sense, since I am trying to create an un-realistic effect. So, basically, I would have to have something really close to the camera for this to work. My goal is to create something realistic, yet interesting, on my scenes.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              tilt-shift
              This works good. You can do the same thing in Photoshop, using a gradient and blur (as mentioned above), but this is much more fun!
              http://tiltshiftmaker.com/
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Just about the easiest approach is to render the z-bufffer pass and use that as a mask in PS. Then save it as a channel and load it (z-buffer channel) as a mask to use the camera blur filter.
                  I second lowering the f-stop....those settings there are a simulation, they aren't a real camera so you can go as low or high as you want...PS DOF is pretty sketchy at best, but for just trying out different levels of blurriness it's fine.
                    if you really want to do DOF in post, frischluft lenscare is the only way to go
                      Or Richard Rosenman's DofPro
                      http://www.dofpro.com/
                      For me, too much guesswork and time wasted doing dof in render. Not to mention longer render times...
                        I own a seat, and used it a couple times, but not for awhile now. I never got the animating DOF to work in it.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          I use dofpro as well, in my render elements I like to have around 4-6 z-buffers so i can combine Dof effects as well as fog....to me in my workflow having DOF directly from vraycam is not an option.
                          show me the money!!
                            no way to use that in AE yet though right?
                            • #15
                              Lenscare by Frischfruch is an option for you for AE
                              Martin
                              http://www.pixelbox.cz
