hi
i'm working on a arch interior animation with moving objects. so i will render the IR prepasses (animation prepass) for each frame and then blending 5 together for one frame. so far i understand i can use pretty low settings for the IR, because they get blended together and will be theoretical 5 times better in resolution than a single one.
if im wrong so far please correct me
so the point is that it takes pretty long to render a single beauty pass. is there any technique or idea i should get used to it to speed things up for my beautypasses?
because i really cant imagine it should take that long. so i'm pretty sure im doing something wrong or at least not quite right
i orientated myself on this tutorial, which i found a bit more simple to get along with than the chaosgroup one. or at least it made me understand things a bit more.
http://www.mintviz.com/blog/flicker-...on-using-vray/
thanks for that to mintviz!
