MatID's in reflections
  • MatID's in reflections
    I just learned that the Raytrace material has an option to pickup reflections for Mat and Object ID's, which seems perfect for creating an alpha for reflections. Is there any way to do this with Vray Material instead?
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
    I think that there was a thread about it some time ago and you could play with vraydirt map to get alfa maps for reflection.
    Best Regards
    Tomek
    Portfolio: http://dtown.pl/
      I am not aware of a way to do it with a dirt map, I'll see if I can find that thread. There are other ways of course, but if the MatID's could be made to work in a reflection that would be a much simpler way, and a more versatile one than the routes I know.
      Brett Simms
        Found the thread and I was aware at some point, just totally forgot about that trick, thanks!
        However, having the MatID affected by reflection would still be ideal so that it would be possible to isolate objects in the reflection as well for cases where you needed the more precise alpha, or just for things like colour shifting of selected objects etc.
        Brett Simms
          This is already done for newer builds, I think. There is "Affect channels" option for reflections too, which allows them to propagate all render elements.
            Awesome - I'll try that affect channels option. Thanks!
            Brett Simms
