VFB, Max Render Window, and V-ray Lens Effects inquiry
  • VFB, Max Render Window, and V-ray Lens Effects inquiry
    Question about the V-ray Lens Effects...
    When I am rendering to the VFB and playing around with the V-Ray Lens Effects, the standard max render window pops up every time
    I update the affect. It does it as well when ""Interactive" is ticked.
    Is there a way to stop this behavior? (It's really annoying to keep closing that every time.)
    Sorry for the off-topic but for us it's a big disappointment that this nice lens effect is only a post production effect in the first place. This way you can just take the picture into Photoshop, do it yourself and it will be the same
    David Slachta
    The Looop CGI
    Shanghai, China
      Yes - do not close it The V-Ray VFB will be pushed on top of the 3ds Max frame buffer and the 3ds Max VFB will stay out of the way in the background.
        A post effect is the only meaningful way to implement this. I'm not aware of any other way this is done in any piece of software. This is because doing a physical simulation is a) excruciatingly slow and b) hard to control.
          Hello Vlado, is the fix for this available soon or?? Starting a big project soon and was hoping it would be fixed.
          Thanks, JR
            The 3ds Max VFB popping up? I can't fix it for the moment, unfortunately; 3ds Max goes to lengths to make sure its frame buffer is visible. Just leave it as it is - like I said, while it's open it will stay in the background.
            On the other hand, we are working on adding the lens effects into the frame buffer itself, which will solve this particular issue.
              Ooops, I am sorry. I was actually posting the question in the wrong place...
              I meant to ask about this problem...
              (Sounds like a nice solution for the lens effect, though.)
              Thank you.
                Sorry for the delay; will get it to you a bit later today.
                  Thank you very much Vlado
                    please do send, thanks
                      I'm wondering why sometimes when i update the effects it starts rendering all over again and other times it just updates the glare/bloom which I want.
                      How does it work ? Do I need to have the effects window open before I hit render ? or has it nothing to do with that ?
                      My steps are,
                      Add Vray effects
                      Hit render
                      open the effects window
                      make changes to get the glare effect I'm after.
                      What would make it rerender the scene ?
                      best regards
                        Hi, I have also experienced this and just thought I did something wrong, but never figured it out...
                          even if it seems strange, but yes, leave it open, then lens effects works as expected, well ...more or less
                          Alessandro
                            Thanks Zeronove,
                            I'd like to know if this is by design ? or its a bug ?
                            Its a pain to render a highres render, adjust the glare and it starts to re-render all over again.
                            It should work regardless of opening it before hitting render and any other changes I make to the scene after the render has finished.
                              It doesn't actually.
                              I tested Vray Lens Effects and even made a small tutorial about this.
                              It re-renders the image only when you go out of VrayLensEffects and make changes.
                              But I had problems with "interactive" mode. It freezed and crashed. Without interactive mode, all seems fine.
                              First make a render through the VrayLens Effect window.
                              Then every time you change a parameter, click update.
                              for my blog and tutorials:
                              www.alfasmyrna.com
