vray glass without raytraced reflection
  • vray glass without raytraced reflection
    i would like to create a vraymaterial-glass without raytraced reflection but
    a reflection map instead. i got a quite complex sky environment mapping with a lot of clouds. when they are reflecting in a building`s windows, it looks quite messy. how can i make a solid color reflect in the winows and override raytraced reflections?
    thanks s.
    if your going to use a reflection map instead of raytracing, why not just use a standard max material?
      because transparent standard max material renders sooo slow compared to vray material. on the other hand, if there is no other way i would do it.......
