opacity map in a refractive material
  • opacity map in a refractive material
    Hey everyone,
    so I've made a search for this but none of the answer I've found seem to work. Or maybe i didn't understand well.
    So the problem is i have a refractive material (water) and i need to fade out the mesh. So in the opacity map I've put a gradient.
    But with that map in, the refraction doesn't work anymore.
    Whats the deal with that? It must be possible but how?
    Thank you!
    Jay.
    You could use a VRayBlendMtl material; leave the base material blank, put the water material in the first coat slot, and the gradient map - in the blend amount.
      Thx for your answer Vlado, will try it out!
      Jay.
