Compositing with Photoshop and LightSelect elements ?
  • Compositing with Photoshop and LightSelect elements ?
    Hello
    I saw the video demonstarting the composition of LightSelect render elements in PDPlayer but how can I do it in PS ?
    Which output should be used as the base for the overlaid elements ?
    Is it a simple beauty render ?
    NIR
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    Screen all on each other...
      yes but what should be the one beneath all the rest ?
        My understanding is that you need:
        Layer5>: Your light passes
        Layer 4: (optional Vray SSS2 and other passes)
        Layer 3: Vray refractions
        Layer 2: Vray reflections
        Layer 1: VrayGI pass
        Layers 1-4 are all added. The light select passes are screen (although I was trying add before so maybe thats what I did wrong) mix mode.
        Regards
        Steve
        My Portfolio
          Thanks
          I think this is exactly what I needed to know.
          Nir
            I may be wrong as I don't use this workflow much at the moment so it would be good to get confirmation from someone that does
            Regards
            Steve
            My Portfolio
