hi!
I tested an animation with multiframe and single frame... the animation has some moved objects (industrial robotors)... what I found out is, that with single frame the animation flickers a lot and with multiframe the animation is nearly perfect!
Is it right that single frame greates a new IM (every frame) which is allways a little bit different to the previous frame and multiframe takes the IM from the previous frame and only changes what`s necessary!
...so I found out, that this is the thing which makes my animations flicker...
.....can I fix this
- problem
....does anyone have an
thanks a lot
hofi
.....can I fix this
thanks a lot
hofi
