How to mask vray distance texture?
  • How to mask vray distance texture?
    Hello,
    i am trying to mask the distance texture....specifically the NEAR texture through the standard max MASK, using bercon maps fractal noise....
    BUT
    i am not successfull...it looks like its not even possible
    Can you guys confirm this is possible or not?
    Thanks a lot
    Best
    Martin
    http://www.pixelbox.cz
    Anyone?
    Vlado is it possible to mask the distance texture within the VrayDistanceTex???
    Thanks
    Martin
      I did not really understand the question... can you describe a bit better?
        Hi Vlado,
        i am looking for something similar such as "radius texture" in vray dirt
        i thought that by plugging in for example a fractal noise map into VrayDistanceTex into "distance" texture slot will give me a similar effect but for some reason its not doing this...
        basically i want to achieve irregular pattern along the places where distance tex takes effect...
        Hope this is more clear...if not, i will send a scene sample
        Best
        Martin
