about a Interior animation
  • about a Interior animation
    hi all!!!!
    I'm doing a animation project now,I need to use Vray rendering.My animation is a Interior animation.i want to camera move and object move,how can i reach this?could you pls advise me how to set the parameter to advoid flickering? if rendering with single frame, can i render over network?
    Yes, Single fame network rendering will work.
    So use Single frame and change your Irradiance map presets to Medium-animation or High-animation. That should do it in most cases. You can at least start from these presets and then change to Custom to lower values for faster rendering.
    When you change over to Custom the one value you don't want to lower is the Max rate of -1 or higher. If you have a random flicker most likely this value should be raised.
    I've had Multiframe work for some animated objects but this isn't always the case. If it will work for your animation this would be the fastest way to go.
    What are the moving object like?
    --Jon
