This is slightly tricky to explain, but basically I can't find a workable way to use VRay Dirt on thin objects without doing something like deleting the back face, which isn't ideal. Would it be possible to have a setting/tick box that allows you to exclude each object from calculating itself... Not sure how else to explain myself, perhaps a picture would help.
Vray Dirt - Exclude self
Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
www.robertslimbrick.com
Cache nothing. Brute force everything.Tags: None
Fantastic. Thanks Vlado.Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
Any news on when we will see this?Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
+1 on thisAMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiÅ™Ã-matys-195a41a0
is this what is causing my problem here:
http://www.chaosgroup.com/forums/vbu...-dirt-odd-gaps
doesnt look like the same effect but might somehow explain it...?
guess a test without backfaces is in order, although not an option really as its a refractive object.
Try deleting the back faces to see what results you get. Could possibly be causing your problem. I'd love to see this feature introduced though.Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
Originally posted by super gnu View Postturns out there seems to be an issue with using vray dirt in the refraction slot, you have to turn on "consider for gi" in the vraydirt settings or you get the errors i was seeing..Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
Guys, it's been a while. Any update? Will this make it in to 3.0?Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
Nobody at all?Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
Thank youWould be such a useful feature to have in VRay 3.0; I could then really start using it on almost everything.
Still nothing then?Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
