VRayPhysicalCamera film gate vs standard Max aperture width
  • VRayPhysicalCamera film gate vs standard Max aperture width
    Hi all,
    We've got a pretty standard lens-matching approach for live action footage with standard max cameras which works well - set the aperture width in the render dialog to the film back width/sensor width, plug in the lens focal length, and bam, perfect match (well, pretty close depending on distortion).
    I'm having a problem achieving the same result with the PhysCam... in this case the footage is shot on an Arri Alexa (sensor width is 23.76mm) and a 40mm max standard camera matches with the live plates shot at 40mm with 23.76mm aperture width. To get the same FOV/framing with PhysCam, I have to change the lens to 31.431mm (FOV 33.083, same as the max camera)
    Am I missing something? Has anyone had any luck matching real world lenses (in this case a Cooke s4) to the VRayPhysicalCamera?
    We are still in 2010, but using VRay 2.25.01
    cheers,
    Josh
    just use your standard camera, then use Lele's script to convert the standard cam to physical cam
    Kind Regards,
    Morne
      Thanks Morne, though I was really hoping that there may be a technique where I could actually plug the 40mm focal length value into the PhysCam and get an accurate result. Seems odd that a camera that is meant to be physically accurate doesn't work with such fundamental values. Again, I'm probably doing something wrong, but if anyone has a solution or an explanation that doesn't involve a workaround, I'd be keen to hear it.
      thanks
      Josh
