vray light rectangle light option
  • vray light rectangle light option
    what is the "direction" parametre of the vray light "rectangle light option" ?
    Is 0 = light is perpendicular to vraylight and 1=very diffuse light rays at a 180degree angle ?
    thanks
    yes, that is correct, but it is the other way around
    0 is 180 degrees and 1 is perpendicular
    Kind Regards,
    Morne
      (didn't see anything mentionned in the help files)
        You may find that the "meaningful" range is in the upper end only. I haven't used it in a while as it doesn't work in RT yet and that messes with my lighting workflow, but I found that values of .88-.99 were the workable range. Below that it gets harder to see much difference - but that may have been tuned up a bit since last I looked at it.
        /b
        Brett Simms
        www.heavyartillery.com
        e: brett@heavyartillery.com
          Yes, it was changed
