Mix image background 360 sky image and vraysky
  • Mix image background 360 sky image and vraysky
    Hello,
    what would be the correct workflow to have a sperical background sky image that is "tweaked"/mixed with the vraysky to get it's intensity ?
    when using LWF, i find it very difficult to have a correct background sky that kind of is "correct" with the sun intensity.
    so that's why i thought of mixing... (used a vraycomptex to mix a .jgp background and a vraysky, but didn't really worked out...)
    Thanks
    put the jpg in a colour correct and push it till it does work, i've been doing it with comptex's for years and it works fine.
      yeah but how can u mix it well with vraysay, which changes the environnement with the sun position ?
        I have done this once. I used the opacity slot, I think.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          I put a camera at 0,0,0 and align the target to the sun. Then put the jpeg in the environment and make visible. Rotate the jpeg until it lines up with the sun. Now you have your rotation values for the bitmap that match your sun position in the VraySky.
