RT and DR CUDA Hardware?
  • RT and DR CUDA Hardware?
    I'm building a couple of 12-core Servers to use for DR. Since my client machine is limited to a single 1GB CUDA card, would there be any benefit of outfitting the new servers with CUDA cards? I do large single frame renders, but like to use Active Shade when I can to see what's going on with lighting, etc. I then use CPU's for the final renders at that resolution.
    Secondly, I noticed that by default, the ActiveShade Engine is set for CPU. Is that for any particular reason?
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    There are some caveats in getting the GPU to work on the render servers; first, you need to actually have something plugged into the video output of the card, second, unless they are Tesla cards, you need to be physically logged onto the machine and run the V-Ray RT render server manually (or at least not as a service) for the GPU to be accessible to V-Ray.
      Interesting. So aside from those caveats, is there any real advantage? Or would it be better to just have a better client machine with a couple of beefy CUDA cards?
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Having the cards locally is always better, but there is often a limit on how many cards you can plug into one machine. DR works quite well too.
