Slate Material Editor's Red Flag
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
I don't think so. I have a v-ray material on my seamless cyc that stays the same no matter if I hide or freeze the entire element in the scene.David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
Actually rivoli is right, it is an indicator that viewport preview for this material is active. If you select the material node and press the "show shaded Material in Viewport" button in Slate the red flag should disappear. However, not every Material supports this feature like for example VrayBlendMtl. A simple VrayMtl on the other hand should work fine, did you check if maybe your Display mode is set to Object Color?
You're right. I see what you're talking about now. It's weird though that the "Show shaded Material in Viewport" button is greyed out when I'm in the Slate mode. Works fine in the Compact mode. Is that a bug?David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
