VRay MaxScript question ...
  • VRay MaxScript question ...
    Hi guys,
    I'm trying to write a script to automatically set certain VRay material values of all VRay mats in the scene, by entering one value in the script. But how do I avoid the script trying to set specific VRay material settings in native Max materials in the scene, causing an unknown property error?
    Here's my script so far:
    MainFloater = NewRolloutFloater "Set VRay properties" 300 315
    Rollout VRaymat_prop_refl_subd "VRay mat refl subdivs"
    group "Refl subdivs value"
    label enterreflsubdvalue "Enter refl subdivs value for all VRay mats in the scene"
    spinner reflsubdvalue align:#center range:[1,1000,15] type:#integer scale:1 fieldwidth:45
    button setreflsubdvalue "Set refl subdivs"
    ) -- close group
    on setreflsubdvalue pressed do
    for i = 1 to sceneMaterials.count do
    sceneMaterials[i].reflection_subdivs = reflsubdvalue.value
    ) -- close rollout
    AddRollout VRaymat_prop_refl_subd MainFloater
    Thanks very much in advance for your help.
    Cheers,
    Metin
    Sevensheaven.nl — design | illustration | visualization | cartoons | animation
    Got it figured out. The important part of the script now reads:
    for m in sceneMaterials do
    if classof m == VRayMtl then
    m.reflection_subdivs = reflsubdvalue.value
      well, brute and slow method:
      try sceneMaterials[i].reflection_subdivs = reflsubdvalue.value
      catch()
      better:
      if sceneMaterials[i].reflection_subdivs != undefined then sceneMaterials[i].reflection_subdivs = reflsubdvalue.value
      in case this doesn't work:
      if ((classOf sceneMaterials[i]) == VrayMaterial) then sceneMaterials[i].reflection_subdivs = reflsubdvalue.value
      something like that...i'm not sure if the classOf is really VrayMaterial, you have to try it out.
      Marc Lorenz
      ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
      www.marclorenz.com
      www.facebook.com/marclorenzvisualization
        Thanks Plastic,
        My method seems to work, so being a script sucker I guess I'll leave it that way.
        Cheers,
        Metin
          yeah it's the fastest way anyway...you just don't really need all the brackets
          Marc Lorenz
          www.marclorenz.com
            But it looks like I'm a real programmer that way.
              By the way, the first version of my script "The VRay automator" is finished. You can find it here:
              http://www.metinseven.com/menu_goodies.htm
              Spread the word and lemme know if you've got cool suggestions for the script.
              Cheers,
              Metin
