Hdr dome lighting horizon
  • Hdr dome lighting horizon
    We use Vraylight dome with hdr map inside for lighting, but are very often annoyed back the fact that the hdr map is then in middle of the frame, causing black bottom inside reflections and such. Is there a way to lower the horizon of the dome so we can adjust this ?
    Is the HDR map a full dome? If yes, why don't you make the dome light fully spherical?
      Fully spherical does work in RT but not in production renderer, doesn't change anything.
        That would be odd (they use exactly the same code). Can you post a scene where it doesn't work?
          After checking, it doesn't work either in vrayRT or prod renderer.
          Check your pm for the scene please.
            ah !
            "vlado has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
              Basically :
                You can email a scene to vlado@chaosgroup.com - those private messages fill up faster than I can manage to clear them, so I've given up
                  didn't wanted to flood your email msg sent.
                    I'd like to know the outcome of this, I've had the same problem in the past.
                      Any insight on this Vlado ? Did you received my email ?
                        I would like to know this as well. I am having same issue with dome and hdri images.
                          Please send this scene to: support@chaosgroup.com instead.
                          So we could investigate further on.
                          Zdravko Keremidchiev
